Clapton mid boost circuit
Stonker
Has anybody tried fitting a Clapton mid boost circuit to a Warmoth Strat body?
The battery box goes where the circuit board is normally fitted.  I wonder if there would be room in a swimming pool rout?
If you can get that little bit off the control rout, knocking it down to a 50's style rout (See picture), you may be able to drop it in there instead, assuming there's enough clearance between the circuit and the pots / wires. Could you accommodate for an 8-screw guard?
Stonker said:
Possibly.  I'm doing a different project at the mo but am thinking ahead
Never a bad thing.
Personally, to avoid the use of a battery box, (As I honestly don't like them anyway) I'd rout for the battery like it is on the actual Clapton strat. the battery is positioned just to the side of the springs, under the trem plate, with an access hole from the circuit routing to the cavity for the wires.
156933d1355916200-blackie-strat-convince-me-please-image-2653136888-jpg
