Circle K Strings....
BassmanAK
Last week I installed a set of Circle K strings on my Modulus. http://circlekstrings.com/store/
Some thoughts:
If anyone has nailed the "Steel meets Nickel" sound, these strings do. There's a body to the tone that really adds a good amount of low-mids to the sound of this particular bass that makes it a lot meatier than it has ever been. It's a bit like a P-bass meet's J-bass tone. The clarity is there, but also the balls in the low range.
The gauge I selected was what they call a "Balanced" set. The sizes are: .142, .106, 80, .58, .43.
This has been the biggest revelation to me. It's sort of similar in concept to "Heavy bottom, Skinny top" but not quite. if you've ever wondered why some of the strings in your set are looser than others, here's why. It was really the biggest improvement over a "Traditional" set. The same attack, pressure, and tone can be applied to the ENTIRE instrument. No more walking on eggshells with your low 'B'!!!!!
Overall, these might be the thing that ends the 34" vs. 35" scale argument. I say that because even with the 35" length on the Modulus, many string sets I tried were lacking  in the low 'B' category.
I HIGHLY recommend 'em. They're a bit on the pricey side, but i'm pretty sure I'm not gonna go back.
NOTE: These do NOT work with a through-body bridge. As you'll see, the gauge selection tops out at .200 (!), and as such, the lower strings are taper-wound. So you'll definitely want a slotted bridge to mount 'em if you get crazy with the sizes.
+100 ... and CircleK is run by a great buch of guys as well. at the Jan 2010 NAMM show there was only one person manning a booth wearing a utili-kilt  :guitarplayer2:
I like these strings so much that the balanced set will be stock my M-Series line of bases
all the best,
R
Those seem like bad fat strings! haha, bad fat so i dont say something offensive in a good way! haha they look interesting,
Using rotosounds or will be on my new five string the swing set, dont think the b string is anywhere near as fat as them
BassmanAK said:
I REALLY dig your work!!!
Do you do 35" scales?
thanks!
yes - with one small exception (a model I don't presently offer) all of my offerings are available in your choice of 34" or 35" scale
all the best,
R
