NoDa75 said:
Warmoth guitars are great, but is a guitar from parts ever going to match the sustain and synergy of a pre-built guitar like PRS, Ibanez, or Fender. What I mean by synergy is the way that every part on those pre-made guitars is designed to fit together and work as one complete guitar system, if you will. Sustain is another important thing. When you have a guitar that is built from parts, there are so many factors that could effect sustain, because the parts aren't designed specifically to work together. As Paul Reed Smith said, "A guitar that sustains for 45 seconds is going to be a much better guitar than one that sustains for 10 seconds."
I am not going to comment on PRS because since so much of their fame is around set-neck guitars.
But as far as Ibanez and Fender go, their process is NO different from a partscaster.
They aren't designing individual necks to fit individual bodies.
They mass produce the necks and send them on to assembly.
They mass produce the bodies and send them on to assembly.
Then they are assembled. The people doing the assembly aren't doing any real special matching (other than maybe some catalog specs in regard to body color and neck material)
There is no real magical synergy in their process. And you sure as shit aren't going to get "more " sustain from them from that.
I'm not knocking Fender--I think most people here love what Leo Fender brought to guitars (and basses and amps), one of the KEY aspects to his greatness was recognizing the benefit of his designs--they were economical, customizable and you could replace the neck if you needed to.
That is exactly the same in most regards to when you put together a Warmoth build--with one pretty important difference:
What you are getting from Warmoth is by and large superior.
With very few exceptions fitting of the neck and pocket is FAR more exact on a Warmoth. If you want sustain on a bolt neck guitar, you would be very hard pressed to do better than with a Warmoth.
What can you get from the Fender Custom Shop that you can't get from a Warmoth? I can think of a TON of things you can get from a Warmoth that you won't get from Fender.
The only issue you will encounter is resale value. At least for now.
