Cabronita Pickguard on a Chambered Body?
MMueller
New to forum.
I noticed that Warmoth doesn't sell a pickguard with the body if you ordered a chambered tele.  Has anyone successfully attached a pickguard to a chambered body, and not caused problems with getting wood in the chambers?
Any hints or ticks?
Thanks,
Matt
The chambering rout is programmed to be solid under the portions where screws would go into a conventional body.
You should be fine.
I don't see why chambering would have anything to do with pickguards. The laminate top is always going to be thick enough to take the screw, so it doesn't matter if you drill into a hollow area.
Right. 1/4" is as thin as it gets, and that's always a hardwood. Then, the number of screws is well past what is necessary to hold the thing on.
