B3Guy said:uh, you realize that is a semi-hollow, not a hollow-body, correct? FWIW, you can get any number of W bodies in carved top semi-hollow, with double f-holes, no less. :icon_thumright:
richship said:Pretty similar to a Warmoth hollow VIP with double f-holes. I like the position of the f-holes more toward the bottom of the body than the VIP and the price is nice.
I think I saw a 335-type kit guitar from BYOG on ebay at some point. It was one of those that includes all the hardware for $200, so I don't know about the quality.
Here's a set neck kit that has tempted me:
http://precisionguitarkits.com/Les-Paul-Junior-Double-Cut-Kit.html
Uncle John's Band Fan said:richship said:Pretty similar to a Warmoth hollow VIP with double f-holes. I like the position of the f-holes more toward the bottom of the body than the VIP and the price is nice.
You can get the exact same kit from BYOguitar for $100 less than where you were looking. And I bet they are the same kits.
BTW there is absolutely nothing wrong with these kits at all. No less work than an unfinished Turtle body and neck..... Plus the BYO kits have proper set neck construction, unlike Warmoth which only offers Fender style bolt on necks. These kits are a good buy and in the right hands will finish out to be something way more impressive than a bolt together Warmoth.
http://www.byoguitar.com/Guitars/Electric-Guitar-Kit--LPJR-Double-Cut__BYO-LPJR-DC.aspx
Uncle John's Band Fan said:These kits are a good buy and in the right hands will finish out to be something way more impressive than a bolt together Warmoth.
Cagey said:Uncle John's Band Fan said:These kits are a good buy and in the right hands will finish out to be something way more impressive than a bolt together Warmoth.
You've clearly never built a Warmoth, or seen one in the flesh. If you must have a set neck, then do what you must, but otherwise Warmoth parts are peerless.
rapfohl09 said:Cagey said:Uncle John's Band Fan said:These kits are a good buy and in the right hands will finish out to be something way more impressive than a bolt together Warmoth.
...say what? :icon_scratch:
Cagey said:rapfohl09 said:Cagey said:Uncle John's Band Fan said:These kits are a good buy and in the right hands will finish out to be something way more impressive than a bolt together Warmoth.
I'm not sure how I could be any more clear. What part don't you understand?
