Hi There, A simple procedure for establishing bridge position on any guitar is as follows... If you dont know the scale of the guitar, measure from the "Nut" fingerboard side to the top of the 12th fret, whatever this figure is double it and you have your scale...The bridge starting point for intonation will be half the scale so if you measure half the scale from the top of the 12th Fret wherever your figure comes to this is where the top and middle of the bridge saddle should be. (Example) if your scale is 25.5 then half will be 12 3/4" so from the top/middle of the 12th fret measure 12 3/4" and that is where the middle of the bridge saddle should be. So for the warmouth neck of 24 3/4" half this 12.375" this is where the top/middle of the bridge should be from the top of the 12th fret.
Desperatedan.
