Bridge grounding
Callaham's vintage bridge is good - it has the sidewalls, so it looks vintage, but they're lowered, so they're not in the way. Good compromise.
Jeff the music teacher said:
Hi,
I'll be getting a HSH strat body from Warmoth in few weeks with a hardtail Fender American standard flatmount bridge. I don't beleive the body is drilled for a ground wire to be solder after the bridge... What do you suggest me to do in order to be able to ground it?
Thanks
Jeff
Does Warmoth even do that?  Ship a body that has a bridge route but no ground wire hole drilled?
I've found Teles to be the easiest to ground because they have so many options.  You can do the wire under the bridge.  You can do the solder to tape thing.  You can do an eyelet between the spring and bridge plate.  Some pickups even have the metal plate on the bottom which are self grounding.
On the hardtail Strat, I'd do the tape method.  It's hardly noticeable in the gap between the bridge and pickguard.
As for soldering and surface area and contact and circular mils of wire, all of the wire in a guitar circuit is already mega oversized for the current it's carrying.  It's as small as it can be to still be workable. Compare it to the size of wire the pickup is wound with.  It's the same circuit afterall.  The instrument cable wire is only upsized for durability and signal loss due to distance.
If there was a bridge/tailpiece ground drilled on the W Jazzmaster I did, it was buried in paint on both ends; -not the first to report not being able to find it on the JM's.
I once got a top-routed body drilled for the Schaller 475 with no bridge ground wire hole.  It was a screamin' deal, so that might explain it.
Ah, that explains it.  Seems they should have a method of keeping the holes plugged when they paint, or have a wire already in it.
