jmcecil said:but tuneomatic isn't an option on the strat bodies
So even on the showcase guitars where they are asking what bridge rout you want, it's not an option? That seems weird.Wolfie351 said:jmcecil said:but tuneomatic isn't an option on the strat bodies
Doubt you will ever find one in the showcase, the option is available on the custom builder
Ah I didn't realize routing for the springs made a hard tail hard to do.Bagman67 said:The showcase pick-a-bridge-rout guitars usually have the trem spring cavity routed, which is incompatible with the TOM/STP combo. Any showcase strat with a fixed bridge will likely be pre-drilled for a flat-mount bridge. It's just what the market demands, nothing personal.
hey, thanks for that info. That was very helpful.stratamania said:If you select in the showcase under Strats for Any Hardtail or click the link below you will see what's available.
http://www.warmoth.com/Pages/ClassicShowcase.aspx?Body=2&Shape=1&Type=1&Path=Stratocaster,Standard&bClass=195
Most are flat mount strat Hardtail bridges. There is one recessed Tuneomatic when I looked just now.
The flat mount also gives the option to have it re routed for a 2TEK bridge.
