Hello All
I'm new to the board and hope someone can help. Almost ready to pull the trigger on my second Warmoth build. The Thinline I just completed had the problem of string height with the Hipshot Stainless Hardtail Bridge, almost maxed out set screws. Most likely will have to shim the bridge. I would like to avoid the problem on the next build which is also a Thinline but with the 720 Mod. I really like the Hipshot Fixed 6 string. So, which bridge route do I go with and what floor thickness (.125 or .175) should I use to avoid action issues.
Thanks In Advance
Thanks In Advance
