Ok so lets say you have a guitar brought to you with modified neck pocket heal. such that it leaves it with the area of only 3 of the neck pocket screw holes. I'll use a warmoth soloist body to visually get my point across.
Like this:
Now they want the neck glued in.. and bolted.
The body has no screw holes and they want to use recessed ferrules with a threaded insert bolt on kit. but with only 3 bolts as it looks like there simply isn't enough room for a 4th without getting into truss rod territory.
I said this will be pretty much permanent. The neck pocket is bare wood and the neck itself is bare as well. They fit together very tightly.
But my concern is this, Will the glue truly compensate enough for the missing 4th bolt? I figured this is as good a place as any to ask this question.
Like this:
