BigSteve22
Today was "Wiring Day"! Took longer than I had anticipated, by no longer than necessary. I decided to to go with the diagrams and suggestions graciously supplied by -VB-. Four way switch, (generously supplied by Mr. May), wired up as: 1-Bridge, 2-Bridge/Neck Series, 3-Bridge/Neck Parallel, 4-Neck. Gibson style tone wiring, connecting the Tone input to the Volume output. And because I'm using NF pups, (a Bill Lawrence L-298TL in the bridge and a L-202TN in the Neck), I went with 500K Emerson Custom Taper pots and a .022uf Orange Drop cap to keep thing on the bright side. (I can always change things up if necessary.)
I also decided to try a "Pure Tone" output jack. Upon inserting a cable plug, I noticed that the tip contacts don't give much tension to hold the connection solidly. So, I bent the tip contacts just a bit to give them a little more bite.
Then I ran a twisted pair from the jack to the control cavity.
Everything else is pretty standard. 22AWG wire, rosin core solder, and everything laced up to keep it neat.
My only real problem came when I plugged in to test the wiring: No output in positions 3 & 4, WTF? So, I retraced all my wires, and realized that I had forgotten a jumper connection. Quick fix, retest, all is good.
Next up: Final assembly and set up! :headbang:
