BigSteve22
It's been a while in coming. I bought the first parts in January, and been posting about it since March. The sun has not been co-operative at my house, so really good pix will have to wait. But in the mean time, I couldn't wait to share a first look. Introducing, the Blackbird/SST Telecaster.......
Assembly was pretty straight forward. No compatibility problem with the Babicz bridge. Saddles are plenty tall enough, and it's very easy to set string height and lock it in. I did have to swap out the intonation screws. The supplied screws are M3-.5x16mm, which for a standard 25.5" scale guitar would be fine. But for a short scale Tele, (SST), the intonation point moves forward, towards the nut, due to the shorted distance between the saddles and the 12th fret. I found 20mm screws at Lowe's, and they allowed the extra travel that the short scale requires for proper intonation. They're a bit too long for my liking, and Lowe's only had the cadmium plated variety. I'll be looking for some 18mm stainless screws, although I may have to get 20's and cut them down myself.
The ZeroGlide nut seems to work fine with the standard .047" fret Kevin was kind enough to supply, I don't hear any dissonance playing open or barred chords. Unfortunately I was unable to stop that buzzing of the High "E" behind the nut without a string retainer. I had a Mastery string tree on hand, and it did the trick. Not my favorite, but it killed the buzz.
Currently the action is set at .060" at the 12th fret. I'll let it sit for a while, see where the relief settles in at, and adjust things from there. It's a strange thing though, that although I generally like a lower action, in the .040" to .050 range, the .060" on this Tele is pretty damned comfortable.
I'm also liking the sound of these Bill Lawrence NF pups. Very clean sounding. The 4-Way wiring is a nice touch, producing four noticeably different tones, the series option being noticeably louder than the others. The "Gibson" style tone mod works well, but I believe it effects overall volume when changed, which I didn't notice with the standard setup combined with a treble bypass. I'll have to live with it a while, may take some getting used to.
I'll post better pix when I have them, as well as full specs and updates on the setup as I go. I'll do my best to get some sound clips for those who have asked. Got to see if I can play with the settings and maybe get something decent out of my little Fender "Slide" interface and my Reaper DAW. I may need some guidance....
