Black Korina finishing opinion
cableman
Hello all, I am new here and after reading these and other guitar finishing forums I have a question. I just ordered my first body from Warmoth. A thinline f hole tele, rear routed with standard thinline controls. Black Korina back and top. It will be finished natural with tung oil. Here,s my question, Before I put on stew mac black water based grain filler, do I put the 50/50 mixture of tung oil and mineral spirits. Some of the stuff I read says to put it on first, lightly sand and then grain filler. But then I read grain filler first (3 or so coats) then 50/50 mix. I have also read 50/50 mix of tung and varnish. I have never used grain filler before and wanted to know what has worked best for you guys that have used it. I was told 4 weeks out for the delivery of the body so I will have time to experiment on some test peices but no Korina so I can't be for sure.
Thanks
jackthehack
Apply the black grain filler and sand back prior to applying tung oil; you will be doing several fills to get Black Korina grain filled. After the first 2-3 fills with black; switch over to clear to finish filling, cuts back amount of sanding needed, but will still leave filled grain black.
cableman
Thanks, but what about the 50/50 mix that is on some of the other post. Before the grain fill or after. Is it necessary at all.
jackthehack
Definitely not before the grain filling. I never thin/dilute tung oil, rather just apply in extremely thin coats and wipe all excess off and steel wool with #0000 between coats. Different people have different methodologies. Experiment with your test pieces and see what you think works best for you.
cableman
Thanks for the advice. That will be how I proceed. If you have time, check out some of the other black korina threads here and a lot of them say to use the 50/50 mix for a few coats.
Thanks again
