Black Ice
ledzepplin6914
I found this thing called "Black Ice" and it controls distortion from your tone control. Has anybody used this? if so any recommendations?
http://www.stewmac.com/shop/Electronics,_pickups/Components:_Black_Ice_overdrive.html
I can't say I own one, but from what I've read on various forums its just a diode clipping circuit.
yep  - that's all it is.  ok I suppose if you like that kind of thing.
Sadly, I don't
Well it's relatively cheap and easily reversible, so you should try it if it sounds good to you. Doesn't sound promising to me. GFS sells some pretty inexpensive onboard preamps that I would probably do, if I wanted that sort of thing.
I got one, was really very disappointed with it.  The only noticeable difference is on the clean channel...Don't waste your money....
Buy 2 diodes, they cost 6 cents apiece:
http://mouser.com/ProductDetail/NXP-Semiconductors/1N4148113/?qs=sGAEpiMZZMutXGli8Ay4kE3wRMDwmh%2f%252bGmXBTkVQdt4%3d
Wire them in parallel, facing opposite directions, and you have just made Black Ice.
But as CB says this is going to sound buzzy and requires you to play hard or use high output pickups.  I wouldn't bother with it.
Found this on youtube and thought it might help a little
http://www.youtube.com/watch?v=awCcC6U-5K4
Have one of these, but I couldn't get it to work with the pickups I had in mind as they were too low on DC output. That, or I didn't wire the ground properly. Then I read it was more of a gimmicky tone adjustment and I dropped the idea. Still have the Black Ice somewhere... :dontknow:
Maybe switch two pickups together in series (two hot single coils) & have the Black Ice in circuit when it throws into series?
The black ice uses...not silicon diodes, which are a .7v PN junction drop (or minimum forward bias, put another way).  I "think" they're using germanium, which is much rarer, getting hard to find, and has a .3v drop.  I think.  If its not germanium, then its some other magic semi-conducting material, not selenium...which is about 1.5v drop.
Anyway, by using a low voltage drop diode, they can clip half a wave when it tops the drop point, lets say .3 volts.  That voltage level is "just doable" in a hot pickup with ok playing.  A really hot pickup might max at 1v, but you cant whack power chords all day.  Reasonable playing might get you .3v or a bit more, which allows the clipping to take place.  I'm not sure if they use one or two diodes (in reverse) but the whole sh'bang can be dialed in using a potentiometer like a tone control
Yo, Zeppelin dude.
Jimmy never needed no "Black Ice".  :icon_biggrin:
