Logrinn said:
One thing I did back in my youth was to unscrew the four middle screws. With only the two outer screws left I had for all practical purposes transformed into a two point tremolo.
That, and a good nut and locking tuners will take you far.
I've read of a method of tightening the outer screws until it is just flush from the bridge and the other four screws to have a little gap between the bottom of the screw head and the bridge to still support it, but haven't read about removing them completely. Won't that put all the tension on just the outer screws without the support from the other screws? Is there no chance of the strings ripping the bridge off the body?
On searching from the internet, I think the options that I have are:
* Super Vee BladeRunner
* Gotoh Wilkinson VSVG
* Gotoh 510T(S)-FE2 or 510T(S)-SF2
The BladeRunner eliminates the knife edge completely and uses a steel spring "plate". It also improves on the arm socket, eliminating any slack. The problem is that I somehow cannot access their website to look for more information. Have they closed or gone bankrupt? It might be hard to find replacement parts if they're gone. It also is expensive and I am not sure if the additional expense if worth it compared to the other options.
The VSVG made the screw holes elongated to prevent binding and also improved on the arm socket. I think it also has more users and has generally good reviews. It is priced the same with the 510T 6 screw series.
As far as I could tell, the Gotoh 510T 6 screw version just improves on the arm socket but the knife edge is the same. It might also need a little trimming of the block hole to accommodate the larger arm socket, though I guess that won't hurt the resale value of the body or guitar as much as converting it to a two point bridge.
Since the VSVG and 510T are priced almost the same, which do you prefer between the two? I am leaning more towards the VSVG as I think it has more improvements compared to that almost stock 510T. If there are other improvements with the design for the 510T, I would like to know them.
Is the cost of the BladeRunner worth it compared to either of the VSVG and 510T?
