B-Bender Tele
then cut the straight lines with a hacksaw blade.  This took me a couple of hours start to finish.
Just an aside, have you discovers the tungsten carbide hacksaw blades? Not the ones that are completely round, but the ones that look like a wide hacksaw blade that's edge has been dipped in glass shreds. Like this:
http://cgi.ebay.com/REMINGTON-HS10C-TUNGSTEN-CARBIDE-HACKSAW-BLADE_W0QQitemZ4391725871QQcmdZViewItem?_trksid=p3286.m20.l1116
I bought two really high grade Sandvik ones ($20?) a few years ago, and it's the best wood, plastic and soft metal saw I've ever used - it just glides through plexiglass, maple etc. It might take like 20 minutes to do the above job, not cutting is harder than cutting with the thing. I still haven't got to the second blade, the first one shows no wear.
Well, that would have sped the job up a little :-)
BTW, more photos coming of assembly and setup of the guitar.
Thanks for all the kind words everyone.  Making that big ass hole was heart stopping at times!
So, with all the holes cut, there was still one potential issue:  Does the B string really line up the way it should?
I really wanted to know before I proceeded with the build, so I did a quick test build.  First, I bolted the bender to the back of the guitar:
Then I put in the string ferrules, and attached the neck
everyone knows about the soldering iron trick for string ferrules, right?
Finally, I put in the ferrule for the pull tower, added the high E and B strings, tuned them to pitch.
The Second Moment of Truth:  Does the B string go where it should go?!?
Phew!  it does!
With that out of the way, I progressed with the build as normal.  More pics later...
Alright!  Now let's put the rest together.
I took the neck and bridge off, and mounted the pickups and pickguard.  I had previously wired the control plate, so I just had to solder on the pickup wires and the output jack.  Here's how it looks with everything soldered up and bolted down:
Then I attached the tuning machines, re-attached the neck, and added the last few bits and pieces (end strap button, string tree, etc).
Then I strung it up, did a stupid fast setup (releif, action, nut, and put the intonation in the ballpark), and then attached a strap and gave it a go!
Well, let me tell you - that thing will pull TWO whole tones!  There is a little knurled adjustment knob on the back near the front that you can adjust the pulled pitch with.  Tweaking that made it into a whole tone.  Then I noticed that when you did a pull bend, at times the bridge would shriek like fingernails on a chalk board (!).  A little oil on the bridge fixed that.
So There it is!  I just have to finish the setup ...  and then figure out actually how to play it :-)
Here's a parting shot showing all of the strings over the bridge.  I'm really happy that everything lines up as it should.
Tonar8353 said:
Great job!  I almost had a nervous break down looking at the pictures!
Seriously :o Great job, man! You have a set of balls on ya for taking that project on.
Yes, I would NEVER do it before the neck and strings been attached to the body... Not that self confident  :icon_thumright:
