mayfly
Epic Member
Hi Folks,
After successfully completing my first warmoth tele, I got the urge to do another - this time with a B-Bender. I figured this was unusual enough to start a new topic for it. And besides, all you tele guys and girls out there have to admit you've always wanted a B-Bender in that guitar of yours.
What's a B-Bender?
A B-Bender is a device that raises the pitch of your B string by a pre-set amount when you press down on the guitar's neck. This actuates a lever that's connected to the guitar strap and via some rods and bell cranks pulls up on your B string. Think of it as a bit of a pedal steel inside your guitar. It was invented by a guy called Gene Parsons specifically for another guy called Clarence White, who played for a little band called the Byrds. Other famous users include Jimmy Page (listen to "all of my love" - ever wondered how he did those licks?), and more recently country guitar hot-shot Brad Paisley.
Installing one of these puppies requires extensive routing of the back of your guitar, plus other bridge and top modifications. Not for the faint of heart!
OK - which Bender?
The first thing that I had to figure out was which bender to use. There are not many out there, but there were some that came with unfinished pre-routed bodies. In the end I was concerned about the quality these pre-routed options, so I decided to use a warmoth body with a genuine Parson's-Green Bender kit. Manufactured by hip-shot, this is the same bender used in fender's Nashville B-Bender tele. To put it in, you just drill a hole for the bender tower through the top, rout out a pattern on the back of the body, then drop it in. Well, it sounds easy - let's see how it goes!
Attached is a photo of the bender, right out of the box and ready to go. Yep, this gizmo bolts to the back of the guitar once you've carved a great big hole in it. This view shows the various levers and cranks, plus the pull tower.
In the next installment I'll show how I made the routing template out of 1/4" lexan.
What's a B-Bender?
OK - which Bender?
