Jack_H
I purchased a set of Seymour Duncan JB & Jazz set of pickups from Amazon back in February. Before I first installed them I tested them with multimeter; the neck had some random reading, and bridge zero. After I installed them the whole thing was full of noise and static, though some sounds were coming through neck, and nothing from bridge.
I took everything apart and re-solder the wirings; the noises remained but nothing from the pickups. This time both pickups were reading zero, as in 0.L. From what I can find out, it means there's a break in wiring. I tried testing on different combinations of wires and different settings with same result.
It's more than likely that I screwed up somehow, possibly with too hot a soldering iron. My question is if there is any other way to check if they are still good, or are they pretty much toast.
