Okay - I made a small mistake on my sanding of my maple top-alder back semi hollow. Due to ignorance, I did the following:
1. Received a CNC body that needed final finish sanding.
2. I raised the grain by spraying with water (and it raised seemingly quite a lot).
3. let dry 24+ hours
4. Did first round of sanding to 320, in preparation for first pass water-based dyeing of the wood.
However, on further reading, I have read that one should first do the first round of finish sanding BEFORE raising the grain with water (I did the opposite). But, some folks don't seem to raise the grain at all and just let the first coat of water based dye do the grain raising.
My question - having raised the grain and then done first finish sand to 320 - do you folks recommend raising the grain again and then resanding before putting on the first round of dye?
Or, should I just do my first round of dye and then do some sanding if further grain is raised?
Have a feeling this is a judgment call - but I would appreciate input.
