Cagey
Mythical Status
AGWAN said:Okay, I officially have decided I hate how screws look sitting in the neckplates on contoured Necks.
I've seen more than once where someone has deleted the neckplate, then countersunk holes to hold finish washers
that the mounting screws settle into...
From the looks of those screws, he must have installed inserts in the neck as well. The original post also mentions that those screw holes needed to be relocated, as they're too close to the edges to pull off that trick. That means you've got doweling, finishing, redrilling, etc. to do in both the body and the neck.
So, you really gotta want that look, as it's not as easy to achieve as it would appear at first blush.
