Is there a special procedure for finishing a neck with Tru-oil that will leave it feeling as slick and almost raw as possible?
I'm looking for the closest thing to raw (or Warmoth's satin neck finish) as possible, but with a wipe-on finish, if that's even possible. I've been finishing my new alder j-bass with Tru-oil, and it is coming out looking pretty great (although I'm getting some streaks here and there -- ARG!). But it's a bit different than I'd expected -- namely, it feels stickier the way gloss finishes feel versus satin finishes, so I'm not sure it would be best for my black korina guitar neck I'll be working on next as part of a VIP build.
This is my first finishing project, and I may be doing something wrong. I've been following the directions from Luthier's Mercantile (http://www.lmii.com/CartTwo/TruOil.htm). I've put 3 coats of Tru-oil on my j-bass so far and had planned to go to 5 to see how things look, then leaving it for two weeks to dry, and the knocking back the gloss with a white 3M scotchbrite pad. Perhaps this final drying stage will leave it feeling smoother and more appropriate for my guitar neck.
If folks have any advice for finishing a neck with tru-oil to give it that fast, slick feel, I'd greatly appreciate it. If Tru-oil isn't the appropriate stuff for such a finish, what might you recommend? I'm working in a basement that houses a gas furnace, so spraying isn't really an option (at least not until it warms up and I can do it outside) and I'd like to finish the neck and VIP body (also black korina) with the same stuff so they match. I'll be doing a clear Colortone filler on the neck and body before any finish goes on. Here's the neck in question:
