This morning I started the final sanding and buffing on my birdseye strat neck headstock after applying an F waterslide. I noticed after starting the 1000 grit pass that there was a crack in the finish between two of the tuner holes and it was absorbing the water. There's also a smaller one next to the high E string tuner hole. Pics are below.
What can I do? Is the only option to strip and refinish the whole neck? Thanks in advance for any help or advice.
