Richard Starkey
Hi,
i'm planning to build a 7/8 Telecaster wich i hope would look close to the VA standard Pro L.C. I have, and will obvisouly have, some questions.
Here are my first:
1- I'll probably will install Lindy Fralin P90 pickups (easier to find than Seymour Antiquity in Switzerland). I realize they don't have the same dimensions as Seymour Duncan P90. Could it be a problem with the pickup rout of the body ? (i will have to make the pickguard myself anyway).
2-I'm considering a rear rout cavity with a pickguard above it. I've read a lot about it and will order long shaft pots, but still i have'nt found the exact thickness of the wood i'll have to drill. Does anyone know ?
3- i've also read a lot about pots (250K or 500K) seems like 500K and 0.22uF are the recommended values to go with P90. What about a compromise, 250K volume, 500K tone ? Bad idea ?
4-Do you know if Warmoth can sell some off menu pickups ? Like Seymour Antiquity P90?
I think that's all for today...
Thanks a lot for reading !
Here are my first:
