ruscio
I recently got a guitar with two HBs that also has a coil-split feature, and even though I mostly use the full HBs, I am finding that I like to use the coil-splits sometimes. I've got another guitar with a 3-way strat-style switch controlling two DiMarzio HBs, giving me bridge (series)/bridge (series) + neck (series)/neck (series), and I'm wondering if I can replace that with a 5-way switch that will add coil-split bridge + coil-split neck at the intermediate positions (2 + 4)?
If so, can you steer me toward a wiring diagram for this (with one volume + one tone) and recommend a high-quality switch? (Would I need a "super switch"?)
If not, is there something similar to what I described that you think I should consider instead?
Thanks for any advice!
