Notyethendrix
I'm helping out my friend with his telecaster, putting 2 GFS tele pickups in and changing it to a 4 way switch. Most of you should know the extra position is for 2 pickups running in series. I bought the genuine Fender 4 way switch, and I rechecked my wiring 3 times, but it still doesn't work.
It suppose to work like:
1. Bridge only
2. Neck Bridge in paralle
3. Neck ony
4. Neck Bridge in series
but now the neck pickup is on in all 4 positions, the tone control doesn't work well(it doesn't cut like it used to be)
Here's the diagram that comes with the switch: http://www.singlecoil.com/docs/4way.pdf
What's wrong, anyone had the same problem? :sad:
1. Bridge only
3. Neck ony
