the upper one is for shane, the other one is for Pitchshifter.
I'll explain a bit.
for shane:
for all the pickups, you've got a volumepot. I just noticed I forgot to make a volume for the middlepickup (I assumed it would be a p90, but if its a humbucker, no problem, you only need 2 wires, hot and cold, each brand will tell you which one is hot for volume and which one is cold for earth). but thats easy to do. just think of that wire that goes to the toggle (the round dots near the dark spot, which was a mistake, sorry), as one of the wires that goes to the volumepots of the bridgepickup. you have a hot-out of the vol.pot for the middle that goes to the toggle.
I do not know how the pushpull works, so you need to measure it with a multimeter. use the setting that gives a 'bleep' when the 2 lugs connect. its easy:
you see 2 rows, each with 3 lugs. when the knob is in its down-position, find out which ones make contact. lets say, middle and out (most far away from the lugs of the pot itself!). that means, in its up-position, you get the middle and the outside (near the lugs of the pot!). the hot-wire of the volumepot of the middle pickup goes to the middle lug, thats for sure, and the wire that goes from the push pull to the output, will be soldered to either one of the outside positions. My guess is the one that is near the lugs of the pot itself. but its easy to hear. its just that 2 positions are interchanged. if you have the middlepickup on when the PP is down, just switch the placing of the wire. I hope you understand?
for pitchshifter:
for you, its actually the same. but now with just 1volume 1 tone, a 3way and a pushpull or a 2way, whatever you like.
I hope its helpfull. I dont have somehting like paint, so I had to do it by hand.
