So is there any way for me to wire the concentric pots for the pickups? or can you at least give me a wiring diagram so i can understand betterDan025 said:sure it's possible, bit it will get annoying when you reach for the volume knob and need to remember what pickups are active. especiallyif you use the "alternate wireing that gives better blending and fully independat control over volume.
the 3 way mini switch seems to be a good idea. as for the wirings, i'm planning to use the wirings of the Gibson Es-5 Switchmasterrichship said:I assume the mini toggles would be three way for hum/off/single. DPDT on/off/on switches should work for that. Three stacked volume/tones is a lot to deal with. If you use Les Paul style wiring, only one volume works at a time anyway. You will have lots of tone options, maybe a master volume & tone would be good enough.
IceMan said:So is there any way for me to wire the concentric pots for the pickups? or can you at least give me a wiring diagram so i can understand betterDan025 said:sure it's possible, bit it will get annoying when you reach for the volume knob and need to remember what pickups are active. especiallyif you use the "alternate wireing that gives better blending and fully independat control over volume.
richship said:What about using a Free-Way toggle switch? http://www.stewmac.com/shop/Electronics,_pickups/Components:_Switches_and_knobs/Free-Way_Pickup_Switch.html?actn=100101&xst=3&xsr=45649 It can work like a regular LP toggle, but you could make moving left and right switch the middle pickup in and out. The mini switches could be two-position to switch from single to hum, and then the toggle would select which pickups are active after volume/tone to avoid the problem above. That sounds easier to use too.
richship said:Concentric pots are wired just like two regular pots. I put a picture of one below. Here's the classic two pickup setup: http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2h_2v_2t_3w Adding another to that isn't too hard. The problem I see is that if you use the switches before each volume/tone and tie the pickup outputs together instead of using a switch, all the volumes will still affect the output even when the pickups are switched off.
One more issue: long shaft concentric pots are hard if not impossible to find. Be prepared to remove some material in the control cavity to get them to fit.
