yyz2112 said:
Are you talking about a conversion neck, or the "true" 24 3/4" scale body/neck (7/8 scale)? If the latter, all they offer at the moment is a Strat style neck and body, but will be offering other styles in a couple of months, per a W sales rep.
true there is only one 7/8th body, well two now with the telecaster. but last i asked full sized bodies could be routed to take that neck, i am fully aware of the difference between the 7/8 neck and the conversion necks, i know it may be easy to assume i am confused here.
the neck pocket fits all fender necks but the distance between the pocket and the bridge saddle is less for the 7/8th neck and the mustang neck. warmoth will do complete custom bodies (minus hollow options) if you give a detailed drawing.
the price may be higher, the wait period may be longer and you give up the posibility of a refund but they can do this.
they can not however route a showcase body as they will at minimum be drilled for a ground wire to the bridge. if all else fails a body can be ordered minus bridge pup, ground wire hole and bridge route and the buyer can DIY or bring it to a skilled professional to be completed.
if you DIY the neck may need to be ordered minus the mount holes as they may be different and the body holes are easier to use as a guide.
