eblankenship
Hi all. I'm looking for a little help coming up with a wiring diagram for my soon to be completed tele. This guitar has two humbucking pickups, a single volume, a single tone and a 3 way toggle switch. My original plan was to coil tap the pickups, using a push pull for each pickup individually. After I thought about it, I realized I didn't need that much fine grained control. Tapping them both at the same time with one switch likely makes more sense. Since this leaves me with a free push pull, I thought I'd like to use it to switch between making the humbuckers parallel when pulled out. Is this possible? If I can't make both of them parallel with a single switch, then I'd be happy with controlling just the neck pickup and making it parallel when the switch is pulled out.
I found this diagram which seems to accomplish what I am trying to do, however, I don't fully understand this comment, "Note: to access the series mode, the pickup selector switch must be in the neck position."
http://www.guitarelectronics.com/product/WD2HH3T11_05/Guitar-Wiring-Diagram-2-Humbuckers3-Way-Toggle-Switch1-Volume1Tone005.html
Does anyone have a schematic that they've successfully used in the past to accomplish what I'm looking for? Any help would be greatly appreciated!
I found this video, which is great to hear the difference between series and parallel.
http://m.youtube.com/watch?feature=related&v=WxbaBWPTT2k&desktop_uri=%2Fwatch%3Fv%3DWxbaBWPTT2k%26feature%3Drelated
