I've read through last year's posts (and searched), but didn't find this specific scenario being mentioned. I'm new to wiring a guitar (done many other things), so any suggestions/advice is appreciated.
Actually, I wanted to ask the obvious - can the "5-way Super Switch" (from StewMac) fit in place of a regular 5-Way, and if not, can Warmoth rout the proper cavity to mount a Super Switch? From what I'm looking for, I don't think a regular 5-way would work.
Anyways, here is what I was hoping to do. I plan on building a Warmoth LP Carved Top, with 2 humbuckers. I wanted a single switch that will allow these position:
1) Neck - Series
2) Neck - Parallel
3) Neck (or bridge - not sure yet) in pure single coil - or maybe a Neck+Bridge mix - any advice?
4) Bridge - Parallel
5) Bridge - Series
I really like the tone/sound difference between series/parallel (esp coming from a single coil Fender/Mustang, I sometimes like the "twang"). The only reason I kept the "Single Coil" is to allow the few times I purposely want a "noiser" background - such as with high gain, high feedback - am I wrong to think with SC it is easier to get this sound ("Hendrix"ish crazy feedback) versus a hum-cancelling?
Also, has anyone ever used a "secondardy" volume pot tied to the "series" leg of a pickup (in a series/parallel wiring)? From limited experience, the series wiring is always hotter (usually significantly), so I though maybe a volume pot could be used. This way, if during a song I switch between the two, I can "preset" the volume so when switching, I can "control" the volume difference (even make the series winding "quieter" than parallel)? I would still have a Master Volume. What is the harm in having two volumes in the signal path? Also, what resistance (250k, or 500k) should I use in this case?
Any advice on this setup, or how to wire would be appreciated! Thanks,
1) Neck - Series
2) Neck - Parallel
5) Bridge - Series
