1 piece neck/fretboard finishing?
Just got a 1 piece neck for a Tele build I'm doing, Vintage Modern construction with an unfinished fretboard.  I was planning on doing TruOil for the back & headstock, but what's the best way to finish the fretboard?  Should I try to do TruOil & just rub very carefully?  Or is there some way I can tape off the frets & spray finish?
Or. . . ?
The usual process is to not worry about the frets and scrape the finish off of them afterward. I'd be a little careful of the finish pooling at the edges of the frets when applying.
