Updown said:Hi Zexcoil …. Scott :icon_thumright:
I'm curious about these's in a slightly different way …….
Please tell me if I'm on the wrong path.
Do these have divided individual coils for each string ?
Meaning you could use a break-out box of some kind, to record each string separately.
Along the lines of what I can do using a GK-3 pickup.
So …. :icon_scratch:
As is it's not wired for separate hex outs.
But …. with some soldering iron wizardry, I'm sure you could get the outputs separated in no time ...
It should be a simple job to make a version of this pickup wired to 7 wires (6 for coils + common ground) which
then gets wired into the GK2/3 plug end.
My thoughts were, then plug this thing right into the existing Roland GK2/3 electronics board and ………………… hope for the best! :toothy11:
A more educated approach would be to match the resistance of the coils too ... I suppose … :dontknow:
I like the idea of 13 pin output guitar which does not have to use the additional GK3 pickup.
Something that just users a standard pickup.
The GK-3 thou …. needs to be as close as possible to the bridge, for best results.
This could be a problem .... But I don't know if thats so true.
Something to ponder :icon_biggrin:
Thanks for dropping on by :icon_thumright:
SalsaNChips said:Now those are some pretty interesting pickups. The demo video showcases them well -- articulation for individual strings is stunningly crisp. Also quiet, superb noise cancellation. The technical video was just that and I need to watch it again to get the true essence of the technology. But appears to be a real, bona-fide advancement in PU tech. I hope they make the Tele set available soon as I am in the market for those and need them in like, the next 6 weeks![]()
swarfrat said:Interested in hex, yes, but would the hex output be humbucking? I'm guessing not - unless that was the intent from the getgo. I've got piezos, and I can tell you that thumps and bumps are a real problem. I can only imagine what n*60 hz hum harmonics would do to tracking.
Super Turbo Deluxe Custom said:If each coil's output were treated as isolated, they'd eventually all be in parallel. If the 3 coils where still out-of-phase, whether series or parallel, there's no reason it should hum.
Phostenix said:Super Turbo Deluxe Custom said:If each coil's output were treated as isolated, they'd eventually all be in parallel. If the 3 coils where still out-of-phase, whether series or parallel, there's no reason it should hum.
I haven't seen a schematic of the Roland synths, but I have to assume that the audio signal from each pickup of the GK (or piezo output of a Ghost bridge, etc.) is independently buffered & processed. I can't imagine any time those signals would be summed until after the frequency detection is done - including any hum that exists with the audio signal.
