Steve_Karl
So it appears that getting a wood route hole from warmoth, one could go with rings, later on, if they wanted, just by shortening the screws a bit?
line6man said:Bagman67 said:How;s this?
Why are the routes so HUGE?
rspst14 said:Thanks...can I safely assume that the route will accomodate an F-spaced humbucker withe no problem?
Crimson Guitars said:I hate to weigh in and disagree with everyone but there is a tonal benefit.. at least according to Andy at Wizard pickups who makes most of the bespoke pickups we use at Crimson Guitars.. I had a rant at him one day about 'silly people believing that direct mounted pickups improve tone' as I really can't see how this would do this, when he blew me out of the water and said that in tests he had done there was a clear difference to the sound!! I've given this a LOT of thought and the only real difference is that by bolting the pickup in to the wood you are effectively adding more density to the body.. we know taking density away in the form of tone-chambers changes the sound of your guitar so it stands to reason making the body (which of course is the bit that has most to do with vibrating and tone) more dense will also change the sound you create.. whether this is a 'better' sound or not is up to you! We're starting to delve into the BIG discussion among guitar builders.. what effects tone more, the wood or the pickups? I've wasted hours of time on that one!
Nah, VIP is rounded at the back end...This one looks like a combo of a strat and a jag... :dontknow:Cagey said:Looks like a VIP with a flat top and a forearm cutaway.
Street Avenger said:Crimson Guitars said:I hate to weigh in and disagree with everyone but there is a tonal benefit.. at least according to Andy at Wizard pickups who makes most of the bespoke pickups we use at Crimson Guitars.. I had a rant at him one day about 'silly people believing that direct mounted pickups improve tone' as I really can't see how this would do this, when he blew me out of the water and said that in tests he had done there was a clear difference to the sound!! I've given this a LOT of thought and the only real difference is that by bolting the pickup in to the wood you are effectively adding more density to the body.. we know taking density away in the form of tone-chambers changes the sound of your guitar so it stands to reason making the body (which of course is the bit that has most to do with vibrating and tone) more dense will also change the sound you create.. whether this is a 'better' sound or not is up to you! We're starting to delve into the BIG discussion among guitar builders.. what effects tone more, the wood or the pickups? I've wasted hours of time on that one!
'Sorry, but I have both types, and there's no tonal difference that you can actually hear.
Do you actually think that vibration does not transfer from pickup screws through a plastic mounting ring and through the 4 screws attaching it to the body?? It's all connected. There are other aspects and components of the electric guitar that have a far greater impact on tone and sustain than a body-mounted pickup will.
peter.k said:mouse pad material is the best shim material I have found. It can be built up in layers as required, and is dense enough to give a firm resistance when the pickup is screwed down onto it. All Gretsch Filtertron pickups are directly mounted, and this is what I used to alter the pickup height on my Country Gentleman..
Interesting that you said that. I am looking to raise my TV Jones Powertron a bit and was wondering what to use. Was going to use foam which is under my humbucker.
Do you think the mouse pad material alters the sound on your country gentleman at all?
DangerousR6 said:This is a cool looking body style, what is it?... :icon_scratch:
Looks sort of stratish, but with a twist...
Gauthier said:DangerousR6 said:This is a cool looking body style, what is it?... :icon_scratch:
How'd they mount that HB without the tab routs showing? Rear mount? Is there a trem cavity?
line6man said:Gauthier said:DangerousR6 said:This is a cool looking body style, what is it?... :icon_scratch:
It's easy enough to cut off the mounting tabs and then set the pickup in with double stick tape and shims.
