Fat Pete
Cagey said:The power of suggestion. It's a thing.
Damn straight it is; and a big thing (or so I believe, now you've suggested it).
One feature that sets wood apart from most manmade materials is that it is an orthotropic material, meaning that it has unique and independent mechanical properties in the directions of three mutually perpendicular axes: longitudinal, radial, and tangential. The longitudinal axis (L) is defined as parallel to the fiber (grain), thus along the length of a tree trunk; the radial axis (R) is perpendicular to the growth rings; and the tangential axis (T) is perpendicular to the grain but tangent to the growth rings. This orthotropy is due to the cellular structure of wood. Wood is primarily composed of hollow, slender, spindle-like cells, that are arranged parallel to each other along the trunk of a tree. The microscopic properties of the individual cells such as their composition and structure, their physical and mechanical properties, and their shape and connectivity determine the overall performance of wood.
Wood is a hierarchically structured composite. The cell walls consist of cellulose microfibrils embedded in a lignin and hemicellulose matrix in which minor amounts (5–10%) of extraneous extractives (e.g., oils) are contained (Wood Handbook, 1999⇓; Dinwoodie, 2000⇓). Variations in the volume and chemistry of these ingredients, combined with differences in the amount and distribution of porosity, determine the structure and thus the density and mechanical properties of a wood. While the properties of a single wood species are constant within limits, the range of properties among species can be large. Worldwide, the density of wood ranges from about 100 kg/m3 for balsa (Ochroma pyramidale) to about 1400 kg/m3 for lignum vitae (Guaicum officinale) and snakewood (Brosimum guianense) (Wagenführ and Schreiber, 1989⇓), a value close to that of carbon-fiber-reinforced polymers (CFRP) (Fig. 1). However, even in Europe, which has a small diversity of tree species due to a relatively recent ice age, the density ranges from about 400 kg/m3 for willow (Salix alba) to about 800 kg/m3 for hornbeam (Carpinus betulus) and 950 kg/m3 for boxwood (Buxus sempervirens) (Sell, 1989⇓).
And it didn't get bleeped, not even in South Carolina! ???arealken said:he said "Wood" heh..heh heh
Street Avenger said:The body, and the core of the neck are substantial pieces of wood, and the strings are anchored between those two pieces of wood. That will make a difference. Of course the bridge and the pickups make the greatest contribution of all.
Well Kevin, I can here the difference between a hard ash body and an alder body of the same shape & size. The hard ash is much brighter (high frequencies). There is simply not enough material of a fretboard cap to make any difference in the tone of an electric guitar.Cagey said:Street Avenger said:The body, and the core of the neck are substantial pieces of wood, and the strings are anchored between those two pieces of wood. That will make a difference. Of course the bridge and the pickups make the greatest contribution of all.
I have to disagree here. The fact that they are "substantial" pieces of says that they won't make a difference. At least, the body won't. The neck is long and thin, and can vibrate more. Those clip-on tuners wouldn't work if it didn't. Since the neck is vibrating, that means it's absorbing energy from the strings. Depending on how much and at what frequencies, it will affect the what's left of the string vibration to be picked up by the pickups.
Speaking of which, some types of pickups are designed to be sensitive to mechanical vibrations. They usually take the form of piezoelectrical elements. There's less for them to pick up due to body mass holding things still, but they have little amplifiers to increase the signal from miniscule to small so the main instrument amplifier has something to work with.
That's why the experiment the original poster did returned results that say wood doesn't matter. He used pieces with a lotta mass and no neck. Basically just a body with strings on it.
So, body = little effect. Neck = some effect. Pickups/signal chain/amplifier = most effect.
