I'm having some wiring issues that I was hoping you guys could help with. I just finished wiring my pickups and there's a few problems. It's a 2 humbucker setup using a 3 way mini switch. First of all, somehow the pickup selections from the switch are "up - Both pickups. Middle position - Neck pickup. And Straight down - neck pickup". I'm wondering if this is possible to happen from wiring my switch upside down - it was impossible to tell which end was the top or bottom of the switch but I figured it wouldn't matter. It doesn't seem like this could cause such a problem but I'm hoping it can.
The other issue is that there is a ton of buzzing, I'm guessing a grounding issue. If I touch the knobs or the bridge pole which has the grounding wire attached to it, then the buzzing gets much louder. I've heard this could be from wiring the output jack backwards (hot wire to the ground of the jack, and vice versa). Could this cause such a problem? Which part of a deep panel jack is supposed to be the ground, and which should the hot wire be connected to?
Here's a picture of my wiring diagram. I'll try to post up a more detailed account of the issues later. Any help would be much appreciated, this was my first time wiring and very depressing to find it is completely screwed up.
Thanks so much in advance.
