partialdoctor
Hey guys,
Will be wiring my new strat tomorrow. I am using Single Single Humbucker configuration and want the bucker to be split in position 4 (mid and bridge) and also use a push pull that when pulled will enable the humbucker regardless of position (i.e. plus the neck and mid, or neck alone). I am going off of these two diagrams below. Does this sound reasonable? I can follow these diagrams, but I'm kind of a noob at this.
One main question I have is if this will cause any issues in the 4 position? In that position the pup will be tapped but the push pull should enable full humbucking, right? Any issues here?
THANKS!
THANKS!
