I suspect this should be in the questions too stupid thread but here we go.
I've wired up an LP with Phat cat p90s, now the neck is working fine but the bridge is not. I'm guessing a grounding/connection issue on that pot. My questions, however, is this, and I fear its stupidity: when I flick the 3 way switch to the middle, I am able to adjust the volume on the pot for the pickup that isn't working when I switch to that pickup alone. So I can adjust the volume for that one pickup on both volume pots? That, and also the volume on that pot only seems to work in the middle of the range (high and low volume no signal). Can anyone explain this to po' Cletus?
Cheers guys.
Cheers guys.
