I have a mysterious intonation issue with my guitar.
Here is all the details, if you have any clues to what it could be please share.
Maple neck, 25.5 scale with graphtech nut, The neck is stable and very straight.
Hipshot fixed strat style string thru body bridge.
GHS boomer 10's tuned to Eflat standard.
Sometimes I tune up to E standard to jam with friends here and there.
The intonation once set is great, better than most necks in my collection.
My method of setting the intonation is open string checked against the 12th fret with a strobe tuner.
Like I said once you set it, its real solid, you can play all over the neck with no wobble on the chords at all.
The issue is that it keeps going sharp.
I keep moving the saddles back to correct it and a week later its sharp.
So the saddles on the low E and A string are so far back now that the spring is starting to bunch up.
I checked the neck bolts and they are nice and tight so the neck is not moving.
The bridge itself is not moving and is tight on the body.
It would be nice to change strings and not have to do the intonation every time.
Anyone here ever have an issue like that?
The issue is that
The issue is that
