Why no 24-fret 24.75” scale neck other than for 7/8ths?
Jerryatrick
Is there something about the full-sized 8/8th body/neck combos that make a fret extension on 24.75” scale incompatible?
The full sized bodies can take a 22 fret conversion neck. The 7/8 neck uses a similar blank as a 22 fret 25.5" scale with a 24 fret 24.75" scale. The bodies for each don't intonate with each other.
One area of incompatibility for a 24 fret extension for a 24.75" as for the 25.5" scale 24 fret extension is the neck pickup position. In any event, it is not an offering from Warmoth.
Video on the 7/8
For the shorter 24.75” scale, the 24 fret fretboard overhang on a full size body would be longer by about 4.5mm (3/16”) and the access would also be reduced by the same amount. It makes sense to choose 7/8th style components in this case.
Video on the 7/8
Thanks Stratamania.
🥺I…I didn’t really want one anyway😭
