why is this body cheap?
vtpcnk
http://www.warmoth.com/Showcase/ShowcaseItem.aspx?Body=2&Shape=17&Path=Jazzmaster&core=68&hollow=446&i=JM523#
body seems quite cheap compared to similar others in the showcase.
The listing notes that there is filler in the neck pocket.  If you look at the photos closely you can see that there may have been a little void in the wood in the neck pocket so they added some wood filler.
It will be invisible, hidden by the neck once strung up, hence a good deal for something that you will never see after you put it together.
Yeah, that one is pretty obvious. The neck pocket is filled, as noted in the description.
