White Corian vs Tusq
Bruno
What are the *main* differences between TUSQ and White Corian?
Ultimately, what you prefer and why?
Thanks
Corian is softer, and it works real easily. The Tusq stuff, which I believe is silica-filled Delrin, is so slippery that metal files tend to just slide around until you put on a bunch of pressure, and then it cuts really quick. I find that whole Delrin family easier to work with abrasive wet/dry paper, or diamond or tungsten carbide types of tools. I'm happy with bones, I just keep several blanks around all the time.
As far as sound goes, I've never done any kind of accurate double-blind study with identical guitars or such (NObody ever does those things, they just rave about whatever they bought last). :icon_biggrin: :toothy12: :icon_biggrin:. I can't possibly image there's more difference in tone than you'd get from moving an amp's knobs from "3" to "3 1/2" or something. The delrin/Tusq stuff probably is a bit better about staying in tune with a whammy or bends, but once you learn how to cut a good nut, the bone works fine at that too.
Sonically, I'm damed if I can tell the difference.
If you use your tremolo a lot, the "slipperiness" of the TUSQ is supposed to be a plus.
As I don't use tremolos much, I just select which to use based on the overall look of the guitar.
