Cagey said:Just as well. You'd have been working the headstock finish for a week trying to bury the sticker they supply now - it's not designed for it. Too thick. Then, chances are pretty good it's a gum-based adhesive so it would probably shrink and crack.
The die-cut metal stickers are pretty attractive. Maybe put one of those on once your finish is cured.
DMRACO said:Here is what I did. Waterside in front, sticker in back.
Still needs level sand and polish.
http://www.unofficialwarmoth.com/index.php?topic=19930.msg296641#new
If anyone has any tips on getting ridnofnthe waterside line I am open to suggestions.
Cagey said:I think you'd shred a decal if you tried to sand it. You need to bury it in finish, sanding that in between coats until the decal's face and the surrounding finish is at the same level.
I intend to try it before the summer's out, so I'll know better then.
Cagey said:. Just be careful not to sand down to the decal or you'll be inventing new cuss words.
