Hi. I've bought Warmoth all-maple pro neck with fatback contour and SS frets. I't plays and feels great and everything. But I can't seem to figure out how to set-up the slight relief in this neck - no matter what I do it stay completely straight. I've written to Warmoth for help, they told me to take a tension off at the main big screw at the heel of the neck (like the old Fender necks from the 60's) and to fine-tune it with the side-adjustment screw. I did what they told me and I turned the big screw at the heel about one full turn counterclockwise. It is now very loose - I can turn it with my nail. It is just in line with the other wood. I'm afraid if I loosen it a bit more it would pop off or I would rise above the surrounding wood and than it would cause problem in the neck joint cavity. Side adjust mechanism seem to work fine - the little side screw is about 1,5mm inside the neck and it can go another one 1mm or so inside if I turn clockwise but it doesn't have any effect on the neck relief. I use .11 gauge strings in standard tuning so I think the tension should be big enough to pull the neck in the right direction. But after I did all these things the neck is still completely straight. Any suggestions please??
Thanks
Thanks
