Divination
To most of you these are extremely easy questions to answer, I don't play guitar or bass that much, but I want to order a 6 string Gecko bass for my brother (his birthday), and I just want to know if everything I have in the following list can be assembled into a fully functioning 6 string bass.
Custom Gecko 6 Neck (6bolt mounting holes)
Custom Gecko 6 Body(ASB6/P4, ASB6/P4 Pickup Rout, Gecko 4 Controls: V-V-T-T, Takeuchi TG6 String Thru Bridge, 6bolt mounting holes)
Takeuchi TG6 6 String Bass Bridge (String Thru)
Gotoh GB7 Bass Tuner, Left x3
Gotoh GB7 Bass Tuner, Right x3
Gecko Neck Washers x6
Neck Screw, Set of 2+2 for Contoured Heel x2
Bass String Ferrule x6
Standard Strap Buttons, Pair
Square Side Jack Plate
6-String Active Soapbar Set & 2(or 3) Band Tone Circuit (Duncan Pickups) http://www.warmoth.com/6-String-Active-Soapbar-Set-2-Band-Tone-Circuit-P1404C798.aspx for the exact information.
Gecko Bass Case
D'Addario ProSteel Strings, 6 String Set
I'm worried about a few things though.
Will all 6 bolts to bolt the neck to the body come with the body/neck?
Do I have all the wiring I need to have someone put it together, and be able to sound through an amp?
Do I have enough screws to screw down all pickups, backplate, and such?
If there is anything I missed, or useless items ordered that wont fit with the body, please tell me.
Gecko Bass Case
