Warmoth Explorer Neck - Flying V Style Home made Body
Bullets
Hi everyone,
Few months ago i begin my first Guitar Build, to be sure of the Result i buy Unfinished Warmoth explorer Neck.
Specs :
Warmoth Explorer Full maple Neck
Figured Alder Body + Flame maple top
Tru oil Finish for the moment.
I'm Happy of Tru oil Feeling and Rendering but it's a little fragile, After 3 Weeks drying it's still prompt to scratch easily.
My question how i can harden the finish ? Spray Nitro over TO ? ...
If you have any advice...
Thanks in advance
Shellac will stick to Tru-Oil and harden a little better. Lacquer or polyurethane will stick to shellac, and harden better still.
I don't know. I suppose as long as the coating is thorough, you're done. It's just a barrier, not build coats. I'm going to have to do it soon, and I'm figuring two or three coats so I have enough build to sand on in preparation for the follow-up finish.
Ok will give it a try next week. Just find shellac and nitro can provider near my job, will post the result. Thanks for all, can stop loop my mind on this now.
I know from firsthand experience about the sticky TruOil thing. :sad1:
The trick with TruOil is to use VERY thin coats & let them cure at least 24 hours between coats (I believe the recomendation on the bottle is only 8 hours).  You'll probably also want to sand on every few coats, not on every coat.  A cool tip I learned on here is to get a small rag wet with the oil, then place it inside a coffee filter and wipe on with that.
I don't know how the shellac would do to cover that (I'd certainly defer to Cagey's wisdom on that), but if I were in your shoes, I'd stick the body in a sunny window for a few days on each side, then sand back the TruOil, and build it up several coats at a time.
But then, I'm probably way more likely to mess up a finish than you.  :icon_biggrin:
BTW - that body is gorgeous!  Home made you say?  Very well done!  Will that be the Gotoh 510 Wraparound or the Hipshot Baby Grand?
Hi ihnpts,
The Tru oil have cured, not sticky at all, and for sure the rule is thin coat and longer time within coat.
Thanks for the compliments on the body only a router and few mills, no band saw for the moment, my future buy for sure. The bridge is Wilkinson Wraparound for this one, and a Gotoh 510 for the future one.
A picture in sun rising mode where the truoil shows all its charm, every kind of light change the finish perception
