Hey guys. I'll make this as succinct as I can...
I once used a 22 fret Charvel neck on a Fender-spec body. The 4 neck mounting holes lined up perfectly, but I had to enlarge the neck pocket to accommodate the 2 1/4" wide Charvel heel. The guitar turned out really well.
Now, I'm considering a Musiclander build, using my other 22 fret Charvel neck. I could order a Musiclander body, enlarge the neck pocket, and BOOM: Metal Musiclander
arty07: But, I also have a 24 fret Jackson neck (same heel dimensions as the Charvel). The plot thickens...
I'll have to widen the neck pocket to 2 1/4" either way. I'm tempted to slap my 24 fret Jackson neck in there. Yes, I realize that would put the 24th fret where the 22nd fret is "supposed" to be. But, I could order a Musiclander body without pickup or bridge routes. For correct intonation, I would have to install the bridge a bit closer to the neck pocket. After that, I would do the pickup routing. Sounds easy enough... :doh:
I don't have the skill or equipment to do much in the way of routing. Luckily, I only want a bridge humbucker in this guitar. The pickup mounting ring should hide my non-professional (ugly) pickup route. And I plan to use a Kahler flatmount hardtail bridge, which shouldn't be too hard.
Have any of you guys done something like this? Are there any issues I'm not thinking of?
I usually subscribe to the "Keep It Simple, Stupid" philosophy, which dictates that I should stick with my 22 fret Charvel neck and have Warmoth do all the routing for me. On the other hand, the 24 fret option doesn't seem that difficult. Also, I've always thought the Musiclander's bridge looked too low on the guitar, almost like a baritone. Using a 24 fret neck would shift everything up, and that might look kind of cool.
Super lo-tech mockup:
I'm leaning toward a quilt top with a Washed Black Dye finish and Black Burst back. Something like this:
