tuners gear ratio = size?
vtpcnk
i was actually asking a ebay vendor about the size of the tuner holes of his advertized guitar to get the right fit, for which he replied :
Hi, that is the ratio to get the right size tuner. Tuner ratio's are equal to their sizes. If a tuner set is the 14:1 then they will fit the tuner holes.
is this right?
Yep yep yep
Perhaps not shockingly, you'd be surprised at the amount of misinformation spread about on the internet.
But many people would rather make a fast buck or look like they know what they're talking about instead
of actually learning knowledge - being the fargen icehole morons they are.  :dontknow:
By way of explanation, the ratio is how many times you have to turn the knob to make the post turn one full rotation. So with 14:1, it takes 14 turns of the knob to make the post go around once. The higher the ratio, the easier it is to tune with precision because the amount you turn the knob results in less movement of the post, allowing for more accurate control of the string tension and hence more accurate tuning.
The size of the tuner and the gear ratio are completely unrelated. You should be able to find a technical drawing of the tuners somewhere that detail the dimensions of the post and hence the size hole you need to mount it. If you know exactly the brand and model of the tuners in question, you should be able to look up the specs either on the manufacturer's site or on a site that sells them like Warmoth or Stewmac. Barring that, try a google search. That being said, I wouldn't buy anything from that particular seller just on principle. I don't like people who can't admit they don't know something and give wrong info instead.
what's the best way to get the right tuner fit?
measure the peg holes?
measure the screw hold from the peg hole?
