Hi all,
I'm working out possible specs for a Warmoth P bass order (body + neck), and the one thing I'm having trouble deciding on is whether or not to have a truss rod access rout in the body. The neck will be 20 frets and I don't plan on installing a pickguard (want to see as much wood grain as possible, control cavity will be rear routed), so the truss rod rout would be pretty visible. On the other hand, not including the rout would make truss rod adjustments more of a pain. I spoke with someone at Warmoth, and he said the necks are so stable that I probably won't have to adjust the truss rod that much anyway (apart from some initial setup), so I could probably just go without the rout.
Any Warmoth bass owners out there who don't have easy truss rod access? Any regrets? Thanks for any advice you can offer.
