Patrick from Davis said:True bypass is not such a problem until you reach 50 or so feet of cord. FET Flip flop (what most pedals have) is not that big of a deal until you run 4 or so in a row. As noted above, the true bypass is a cord length issue and over 50 feet is where the issue shows its coloring problems. The FET Flip flop switch has your signal run through at least two transistors at all times, so after four pedals your signal has been through 8 transistors (at least 8, and they are cheapo's as well) which color your sound as well. Damned if you do, damned if you don't. Personally, I do not have very long cords, so I lean towards true bypass. Then again, I use maybe one pedal most of the times. The curse of buying a good amp.
On a side note, wah pedals traditionally have been pedals of much head scratching. The true bypass kits for crybaby's have a very good rep because they cure some of the odd things those pedal do to your signal path, on or off.
Super Turbo Deluxe Custom said:One could always plug directly into an A/B switch placing a Y connector at the amp. Hitting the A/B switch would true bypass any or all effects depending where it was in the chain
Dunlop seems to differentiate the two. They have a true bypass that actually switches the input and output, and the hardwire which only switches the output. The spend a lot of detail discussing this on their blog.yyz2112 said:A hardwire bypass is another word for true bypass, just a matter of where the bypass physically sits in the pedal. It can't be hardwire bypass and still have the board in circuit constantly, kind of an oxymoron.
DMRACO said:Dunlop seems to differentiate the two. They have a true bypass that actually switches the input and output, and the hardwire which only switches the output. The spend a lot of detail discussing this on their blog.yyz2112 said:A hardwire bypass is another word for true bypass, just a matter of where the bypass physically sits in the pedal. It can't be hardwire bypass and still have the board in circuit constantly, kind of an oxymoron.
Super Turbo Deluxe Custom said:Those kick butt.
