I'm working on a Tele project and am now finishing the body (which is Ash).
I wanted a deep, rich, yet still transparent, amber color; and I've been curious about Shellac and French Polish, so I decided to take a chance and experiment with it. After several coats, and lots of sanding, so far the color looks great. However, I'm concerned about the durability of the Shellac by it self (as I've recently read that it does not wear well, and may need some sort of top coat/clear coat).
So, I'm wondering what are my options for a clear coat. I've heard that it is not uncommon to use Shellac as a sanding sealer, with Laquer as a top coat(s). But, I'm wondering if Tru-Oil would work the same way... as a top coat(s) over the Shellac? I've already finished a neck with the Tru-Oil, which turned out fantastic; so I'm happy with the results and like how easy it is to work with.
Apparently, some finishes won't work over (or under) others, depending upon whether they are oil, alchohol or water based... so I'm not sure if these two materials are compatible.
Any help would be greatly appreciated.
Thanks!
:icon_smile:
Thanks!
:icon_smile:
